Drilling hole in saddlebag and what to use to cover the outside ...
I'm installing a Rockford Fosgate T600-4 amp and 6x9 speaker lids in my saddlebags. My question is, for those who have a similar setup, what size hole did you use for your 4GA power, 4GA ground and 16GA speaker wires?
Where is the best place to drill the hole and what did you use to cover the hole on the outside of the saddlebag after you threaded the wires through?
Any help would be appreciated and pictures would be even better.
Thanks!
Thanks!
Painters tape and used a 3/4" hole saw. Start in reverse to help keep from chipping the paint. I also found it beneficial to drill the pilot hole first and then use the hole saw.
8 gauge should be sufficient as well unless you are running the 4 gauge to a distribution block.
paksoy (07-24-2017)
Thanks!
Thanks!
paksoy (07-24-2017)
That's a nice clean setup. Do you have any concerns with water coming through the holes if caught in the rain?
Im not overly worried, but I have some rtv sealant to fill in the holes if I want. And will as often as I've switched things out I don't think I'll use the sealant just to make running wires easier when needed.
paksoy (07-25-2017)
