Upgrade speakers 2014 street glide special
Ok new to cycle audio here is what I want to do. Would like to change out stock speakers with something that can drop in the pods. I purchased a sound stream amp pn2 350d. Was thinking about focal speakers. The 165 ac. I don't want components. What else do I need to do the install? Other speaker suggestions welcome. Thanks in advance.
Well for your basics for a 14+ glide, you will need 6 feet of 8 gauge power and ground wires and some hardware to connect to the battery. 6 feet of 16 gauge speaker wire and likely some female spade connectors. A Biketronics BT355. Stinger 4000 series RCA, I think they sell 1.5' or less.
I've really only seen the Infinity Kappa speakers reccomended for that amp, but I'm sure others will chime in. If you went with the Kappas there would have to be some slight modifying to get them mounted inside the pods, potentially with the Focal as well.
Is there any chance of returning the amp?
