I hope they are not too much bigger than the HAT's, I have to pull up and tilt the lid at just the right angle, and squeeze the edge of the lid past the 7.1 pod's and the magnet scrapes the top lip of the bottom bag...as it is with the HAT's!! I'm gonna try both the Pioneers and the VO's which do ya think I'll keep!
if you have support speakers in your rear stage that will cover the "highs", you will keep the VO, and they mount up with standard hole pattern, im droppin a set of horns in lids on a custom bridge mount, hope to have up n screamin by fri night
With my hogtune lids, I had to open up 2 holes on 1 side to get everything lined up. No sweat.
Just bore out the mounting holes on the speaker and slide that sob just a little bit to get it to fit perfect for the lid clearance. Just a tiny bit is all u will need.
I'm trying to tell folks. These VO's are the truth!!
Just to make sure I'm reading all this correctly, if I'm the kind of guy who is planning on the DD AWs up front, takes my TP off in the summer and does NOT have lowers or in the bag speakers, I still want the Pioneers for my lids, correct?
Either will be fine. I'm partial to the DD's because they have a little more low end. I had a customer running the AW's off the GZ amp in the fairing, with an Arc Moto pushing the Pioneers in the lids and Hertz Mille in the tourpack swap out the DD VO's and he liked those more. I think either will work.
T.
my lids are 5x7 with adapter ring. i know... my fault. lol
