Street Gilde & Road Glide Fairing
RG, at least on a 13 down. You can get two amps one on each side between the glove box and the inner fairing side wall. Still leaves you a little room above the HU for a small/micro amp to run horns if you wanted. You also have more room to cut in holes on the inner for a set of horns than a batwing. I am thinking on my next audio upgrade of removing my glove boxes (don't use them) and sealing the doors to the fairing. This would allow for two much larger amps than my RF TX amps in those spaces. If I did I would add some inner fairing braces to mount the amps to. Now I have some 1" aluminum angle epoxied in as supports, Velcro on amps and fairing to secure them, and the glove boxes sandwich them tightly in place. If I got rid of the glove boxes, I know I need a means of securing the amps to something more than just the inner fairing.
I have a 14 batwing and a 15 RG in my garage right now. Theres no doubt that the RG has more space and it's not close. The RG (pdevores bike) has two Diamond 4v2s, one on each side of the fairing, an Arc 600.4 behind the headlight in the "stock" amp location, a Arc DSP under the radio, a Mosconi Pico under the radio as well as 4-fuse distribution block for the juice and two LOCs to route the signal to the right place. The batwing has an amp over the radio, an amp on the BT Bracket on the clutch side and I'd be hard pressed to fit a ketchup packet in there after that. That's an easy answer, RG by far
B-Bill, shoot me a PM with a number I can text you at. It's here with the fairing off, I can take pics from any and every angle you'd like. It's really quite a miracle that he has all this in here. I'd love to take credit for fitting it in there but that was all pete. Pretty incredible actually
Thanks in advance.
