Amp install on 2011 Ultra HELP!!
Hey guys...ive searched high and low online and I'm coming up with zero on this topic. I have a Candy Ds18 Micro4 amp and I can't make heads or tails of how to hook it up to my 2011 ultra classic with the stock HK head unit. It came with 2 harnesses. One is for the "bridged mono" space on the amp and the other is for the "high output" space on the amp. The plug that goes into the bridged mono slot of the amp has two yellow wires going to the same fuse block and then back out. I'm going to try to add a picture. And there is also 2 ground wires. I'm MADE of questions.....
1. How do I connect this amp without using a RCA converter since there are no RCA inputs on the Amp?
2. Obviously one yellow wires is a remote, and the other is 12v. So where should I put the remote wire if the 12v goes straight to the battery? Usually aren't these wires red and yellow? And the remote is blue?
3. What is the high output For?
I'm connecting 2 Rockford 6.5 3way 4ohm speakers to it for my fairing. I could just use some help figuring out how to do so. Thanks.
as far as the 2 yellow. One was for REM and one was 12v. I ran them BOTH to my battery positive terminal. Amp turns on with the switch in the start position. I ran both ground wires to the top bolt of my crash bar mount where it mounts to the frame. And that's how I ran this amp. Hope this helps someone else
roughneck266 (06-30-2017)
that's what I know to be true also. However, when I holes the REM to a wire that ONLY came on with the ignition switch, the radio and gauges stayed on even after I shut the bike down. I removed that blue REM wire... and hooked both yellow wires (one says 12v and other says REM , to the battery and the power ligh on the amp goes on when I turn my Ignition switch on, and off when I turn it off. So not quite sure why. But that power light on the amp goes off when the switch is turned to off
