U0184 Lost comm w/radio error on a 2016 FLHX
Ok so long story short:
A costumer had a short on the main power line on his 2016 FLHX and the result of that was that the stator went bad and probably the regulator too. We are waiting on those parts but in the meantime I connected the the bike to Centurion to run the diagnostics... well a bunch of codes popped up that after clearing them and making sure everything was properly connected the bike looks to run ok but I still have an U0184 Lost comm w/radio on the BCM and the Speedo. Any thoughts on what's going on?
I must say that the costumer said that he did saw a bit a smoke comming of the fairing when the problem happend but I don't know how to check if the actual radio works or not. Do these radios have an internal fuse or something to check?
Thanks in advance for any help you can do for this strange problem.
