Would this work?
06-19-2017, 08:26 PM
Would this work?
Toying with the idea of running 2 8ohm mids in parallel unbridged off the amp in the fairing, then the same setup for lowers.
Then running my tweeters w/ x overs or horns off the other open channels.
Reason: meant unbridged
06-19-2017, 09:07 PM
Quote:
Originally Posted by SgtMic
Toying with the idea of running 2 8ohm mids in parallel bridged off the amp in the fairing, then the same setup for lowers.
What amps and speaks?
T
06-19-2017, 09:14 PM
06-19-2017, 09:16 PM
not enough power brother. Am I reading this correctly four speakers off two channels and then just horns off the other?
06-19-2017, 09:18 PM
BaggerAudioLab
Yes..
06-19-2017, 09:47 PM
BaggerAudioLab
2 8ohms bridged and horns/ tweets off the other 2 open channels?
To add lowers then I'd need to add another amp.
06-20-2017, 07:42 PM
This is what I'm going with.
Ordered the VO6x9s from Alex for the lids, the Beymas will go bridged and parallel in the fairing and I'll run the AT28s off channels 3 and 4 to test those out.
Worse case scenario I order a set of horns or throw the AWs back in.
06-20-2017, 07:51 PM
I think ur really gonna like those Beymas!!!! Good freq range!!!!
T.
06-20-2017, 07:58 PM
SgtMic
Just checking, these Beyma are 8ohm right? I know you mentioned 8ohm earlier.
06-20-2017, 09:10 PM
matt76cmich
They are. My thought process is if the AT28s don't work out (I think they will) I can add horns later and those need to run off their own channel.
I have 2 amps stuffed in the fairing now. I don't want too add a 3rd or add anything in the bags.
