Wiring and RCAs
What is your amp setup and where is it located? How many channels and speakers?
I have been using Knukoncepts speaker wire (i have used their RCAs as well), Sky High power/ground and AGU fuse holders, Stinger for ask my RCAs. I have either gone through Amazon or the companies direct.
Speakers are as follow: In the fairing I'm going with 6.5 Mmats and DD Horns with a set of Mmat 6.5 in my lower fairings. In my bags I'm running the DD W8.
Amps are as follows Arc 600.4 and a DD D4
I'll also be running the Arc PSM DSP
I'm a little scared dealing with the DSP, but Haze has told me that it shouldn't be too bad.
I'll be running a setup very similar to yours.
I run 4000 series stinger RCA's and NVX 8 gauge for the power and ground. NVX 16 gauge speaker wire. All can be had at Sonic-electronics.
Mixter
08-22-2011 08:36 AM
