Soundstream PN4.1000D in batwing install help!!
Soooooo......
Ive already upgraded my stereo to polk dd651 in the fairing, tour pack, and when my lower speaker pods get here, another set there, and running pioneer 6900 pros in the bags. I have 1 SS PN4 1000d set up in the TP, running the 6x9s and the TP 6.5s.
I can not get the amp to sit at all in the fairing. It leaves a huge gap underneath the amp if i try to match the angle of the fairing, and just sits on the front mount holes. When I sit it flat on the amp, the fairing wont button up correctly. I pushed that bundle of wire up and out of the way and the amp is pushed back all the way to the gauges and the amp still doesnt fit. I really dont wanna run both amps in the tourpack, but i figured before I had to rewire the whole dang thing, I would check with the experts here. I included a couple pics, Thanks!
Almost forgot, Its a 2015 Ultra low. I looked at a couple other posts about this amp and everyone elses amp tray looks different than mine. I really dont want to spend money on an amp tray if i dont have too
HawaiiNighttrain (04-08-2017)
I would take some more current pictures of the amp tray out of the bike BUT forum member BIKEMEDIC has my old amp mount now as I dropped the $$ on a JM tray over the winter while upgrading
T is correct. When I jad tje same amp on my 2014 I used the JM amp tray and still jad to modify it a bit but it sat flat on the tray. You would have to do some serios cutting to get tjat amp to fit right on tje factory tray.
Well I pulled the tray out, "modified it" a little bit, lol, put it back in, put the amp back in, checked all the clearances, batwing fit just fine. Thanks everyone I appreciate it!. I even had time to make a plexiglass triangle (made it too big though) for the amp in the TP to sit on and not worry about it sitting flat and crap getting on it. So a pretty productive day. Again, Thanks everyone, I really do appreciate it
Originally Posted by HawaiiNighttrain
So here is another question, would I be able to run those polks and the pioneer TS6900 in parallel to the amps? So fairing speakers in parallel, lower fairing in parallel to one amp, and the TP polks in parallel and the 6x9 in parallel to the amp in the TP? Thanks in advance!
