Need Help Wiring Reckless FXDF Fairing
Just received and mounted the Reckless Fairing with full Infinity Bluetooth audio for my Fat Bob. Wiring instructions were limited and I'm inexperienced when it comes to HD wiring. There are to wires for positive and one for negative. Has anyone had experience with this particular fairing? The instructions say "Wire the Red wire to your battery negative, and wire the Yellow and Green wire together to your battery positive. These units will not work wired to the ignition"
Without cutting the wires that are physically connecting to the battery, is there a simpler way that will tap into a power source and still work? Thanks!
sorry been in dentist office.
According to reckless you have the following
red, yellow, green wires
green goes to battery - or any good solid ground source such as the frame
red goes to battery +12v (this is what retains your memory in the headunit)
yellow goes battery as well in their installation scenario but the way you want it to work, this wire needs to go to an ign source that its on only when the ignition is on. so connect this yellow wire to the fuse in this picture labeled cust ACCY. when you put the bike/key in accy position the radio will come on as it should.
The following 2 users liked this post by UltraNutZ:
Cpheen15 (03-14-2017),
HarleyDammitt (03-16-2017)
Smcconkey
Electrical/Lighting/Alarm
06-29-2012 11:32 PM
