Need guidance please on install on a 2014 Limited
First of all I'm a newb when it comes to this stuff so something may be installed wrong or maybe it's something simple we did, not sure. Here's what I have. Hertz ECX 165s
Hertz EVF 165s
Diamond micro 4v2 amp
BT 355 (F)
Bt 355 (R)
amp wiring kit have.
When the bike isn't running it sounds decent but really I thought it would have a deeper sound. To be honest the stock system sounded better. Thats why I think something isn't correct. I have contacted the seller and I know they will help but it's Saturday and not sure if they will respond today so I'm asking for help.
When you crank the bike and head down the road you have to turn the bass all the way up and treble all the way down to even stand it. If I lead forward toward the fairing it sounds deeper but still not good. With the radio on I have lost alot of reception and the sound is not good. We adjusted the gains with the fairing off and it really didn't make a whole lot of difference so it's about in the middle I guess.
Any advise well be greatly appreciated so I can look at this weekend.
Hertz EVF 165s
BT 355 (F)
Bt 355 (R)
After u triple check all of the connections, polarity, crossover settings, etc, in the name of managing expectations, that speaker combo is not in the business of getting you the "deep" sound u might be looking for.
Speaker choice is critical brotha!!!! The stuff u have in there might not be what ur ears are looking for.
Good luck!!!!
T
Good luck!!!!
T
Good luck!!!!
T
Good luck!!!!
T
Before you throw your speakers in the trash:
Are you running the stock 6.5 BOOM head unit?
If so, do you know what version the software is?
Did you purchase a Biketronics Break-out harness or are you running the rear speakers directly off of the amp, without any fade control?
Are the rear speakers too bright as well? It seems unlikely since they are a mid-woofer without a tweeter.
How did you adjust the gains on your amp (by ear, multi-meter, distortion detection device or a guess) ? You need to "properly" adjust them with a test-tone, AVC set to off and treble & bass set to the middle (flat).
You also need to be sure the filters on the amp are set/adjusted properly.
Did you leave the adjustments on the BT355s in their default positions (as they came from Biketronics)?
Where did you attach the ground wire from the amp?
Have you double-checked to be sure that polarity of all the speakers is correct?
As T & Gann have stated, there are much better speaker choices. If everything with the rest of your system checks out, then you're probably going to be in the market for fifferent speakers.
Also, your amp is rated at 80 watts per channel x 4. You're not going to get the same results as those who're pumping 150 to 200 watts per channel into a component speaker set-up.
I am running the 6.5 Harmon Kardon head unit.
Wow, wish I'd left it alone now. Sounds like I may be in trouble then. Still not giving up yet, I'll check what I can though. So the amp Diamond amp isn't putting out any amps then ? I thought it was good. We also had to run a wire from the line that goes to the cigarette lighter to get the amp to turn on even though it's run to the battery, why did we have to do that, it should have came on by it self right ?
https://www.hdforums.com/forum/audio...ore-bikes.html
https://www.hdforums.com/forum/audio...-rushmore.html
https://www.hdforums.com/forum/audio...ns-sticky.html - Post #6
The Diamond amp is rated at 80 watts per channel, not amps.
Not knowing how you have everything wired, it's hard to diagnose your problem.
...Does the volume of the front & rear speakers increase & decrease proportionally?
...Can you fade from front to rear with the hand controls and/or the radio screen?
The amp is powered from the battery. It's "triggered" (turned ON) with the 12 volts from the cigarette lighter, which comes "ON" when you turn the ignition switch to ON or Accessory. Some amps are triggered "ON", when they sense an audio signal from the amp, but sometimes that signal is too weak. Always use the "trigger" wire, if available.
Don't throw in the towel. The 6.5 system that comes stock on your bike is called a 6.5 Boom Box. Harley designed it to play with their over-priced Boom amps & speakers. Getting it to work with aftermarket components is more challenging but definitely doable. You can educate yourself by reading the following threads:
