Need guidance please on install on a 2014 Limited
Old 03-04-2017, 11:02 AM
WestTexasRanger's Avatar
WestTexasRanger
WestTexasRanger is offline
Originally Posted by tesnevo
What are you using the phone for during this testing, the test tone?
If so DONT, you need to load the test tone on a USB stick and plug directly into the radio.
You can not use an volume adjustable signal source (phone-iPod-etc) to run a test tone unless you know what the optimal DNR/DB/voltage/signal out the signal source is producing in order to match it to the head unit/receiver at its optimal signal output DNR/DB/voltage/signal and volume.
Very ultra high end audio is done the above way with $45,000.00 test equipment designed for that.
The phone apps are good for testing output signal from source units (RTA-DB-SPL-FFT-etc) but should not be used for for the input signal for testing purposes.
So now to the simple way that's accurate;
When the test tone/signal is coming directly from the head unit (USB) , adjust volume at 4 bars from max and get your amp setting/reading that way only.
When I was tuning my amp, several forum members pointed me to various test-tones that I could play through my iPhone via USB cable. There was even some discussion as to what volume the phone should be set at, with the consensus being 3/4.
I used the Tone Generator from the Digital Designs Toolbox app to set my gains.
So do I need to reset the gains on my system using another test tone and a USB stick?
My system sounds great but it appears (from your post) that it's "Close...but no Cigar".
  #32
Old 03-04-2017, 02:34 PM
tesnevo's Avatar
tesnevo
tesnevo is offline
It's all good brother. The volume that was said to be at 3/4 was to be your head unit.
Your ideal setup is the USB for the gains. For no harder than it is, easily said lol, I'd suggest doing it by USB.
If you leave it the way it is now you have a high probability of your rear fender falling off and both tires going flat.
  #33
Old 03-04-2017, 08:00 PM
WestTexasRanger
Went for a ride this afternoon, stereo blaring and the lenses in my gauges cracked. Definitely going to re-tune via a USB stick. I'll report what, if any changes were needed on the gain settings.
It was suggested that trying the test-tone with my iPhone at 3/4 volume (instead of 100%) might be better, in addition to the head-unit being at 3/4.
I started a new thread about developing a STICKY for setting gains with a DMM. It needs to cover some basics with regard to 2013 and earlier HD radios, aftermarket head units and the Rushmore head units.
I hereby nominate Tesnevo as a candidate for this task, based on his vast knowledge of sound systems and willingness to share it with us who are "technically impaired" at times.
Do I hear a "second" on his nomination?
  #34
Old 03-04-2017, 08:08 PM
Tailwind's Avatar
Tailwind
Tailwind is offline
Second!!!!!
T
  #35
Old 03-05-2017, 01:06 PM
Big Dave's Avatar
Big Dave
Big Dave is offline
Received 1,013 Likes on 558 Posts
Have you had any conversation with the seller , or did they say anything about your expectations . Looks like they left you high and dry , thankfully you had some great help from here
Dave
Melroy
Audio Systems
04-24-2019 03:31 PM
tylerfj24
Audio Systems
07-19-2018 12:31 AM
The Truth
Audio Systems
03-20-2018 09:54 PM
big TYME
08-22-2014 04:46 PM
jeffreyjames
02-24-2008 09:21 AM
Quick Reply: Need guidance please on install on a 2014 Limited
