Inner fairing road glide
What are you putting in it?
Hey KB,
There are much better amp options with much smaller footprints.
At 4 ohms that amp only puts out 50 Watts RMS x 4.
This is straight off their spec sheet.
Model: KXM400.4
RMS Power
@ 14.4V, 4 stereo, 1% THD+N 50W x 4
@ 14.4V, 2 stereo, 1% THD+N 100W x 4
@ 14.4V, 4 bridged, 1% THD+N 200W x 2
Length | in. [cm] 11 3/16 [28.4]
Height | in. [cm] 2 3/16 [5.5]
Width | in. [cm] 8 5/16 [21]
Frequency Response ± 1dB 10Hz–20KHz
Signal-to-noise Ratio >95dB, A-weighted, @ rated power
Input Sensitivity Low Level: 125mV–5V
High Level: 250mV–10V
Electronic Crossover Amp 1: OFF/HP/LP; Variable 10–5,000Hz with X10 switch
Amp 2: OFF/HP/LP/BP; Variable HP, 10–500Hz;
Variable LP, 40–5,000Hz with 10X switch
Slope: 24dB/octave
KICK EQ Bass Boost Variable 0–18dB @ 40Hz
Your going to be really disappointed with your system with just 50 watts RMS.
Look in the classifieds here and see if there are not some much better options
Model: KXM400.4
RMS Power
Slope: 24dB/octave
Its 400.2 not 400.4
Not much different but slightly
I didnt pay for it besides shipping. Its getting wired 2 4 ohm speakers wired to 2 ohms per channel. Should be about 100 watts per speaker. I've ridden the same bike thursday in vegas with the same setup it had 6x9 in the bags and tour pack. Faded forward and I liked what I heard. Kicker rep sent me the stuff. If it don't work all I did was pay for shipping.
