Another Road King Audio Thread
I'm redoing my 2011 RK this winter and was thinking about adding some tunes. I have a Sena helmet system that I use now with my iPhone. It works pretty good for me so I don't need much. I stay on the backroads 90% of the time when I take a trip....so basically looking for some nice tunes under 50 mph.
My setup would be lower speakers and lids. Some bluetooth amp either in the bags or under the seat. I can fab up 6x9 in the lowers if needed, but I'd rather use whats available (Time constraints mainly).
I have looked at a few threads and have an idea, but want to kick it by you all first. Budget wise id like to stay round the $500 mark
Amps (Under $200)
Soundstream PN4.1000D 1000W 4-Channel Picasso Nano Series Class D Amplifier
Cerwin-Vega B54 Stealth Bomber Class D Amp (b54, 4 Channels, 1,200W)
Speakers ($100)
Infinity Kappa 62.11I 150W 6.5-Inch 2-Way Kappa Series Coaxial Speakers
Rears 6x9
Should I run one or two?
Thanks for the help!
Btw here is the bike as it stands
Amps (Under $200)
Speakers ($100)
Rears 6x9
Amps (Under $200)
Speakers ($100)
Rears 6x9
Amps (Under $200)
Speakers ($100)
Rears 6x9
Yes. Definitely need two 6x9's in the lids. From what I can see you're gonna have to increase your budget a few hundred if you want to do right. The Lids alone are anywhere from $2-300 bucks not including paint.
Streetscenes (02-13-2017)
I'll pickup a set of lowers. I can either get the adaptors for the speakers or fiberglass something in if I have to. Good point on the lids...The range I gave was more for the electronics than anything. I'll handle the paint work. Really I just want a reasonable system but I don't need a stereo that is a parking lot concert machine.
Gannicus...I was looking at your post from earlier to another member. Would this be a good start?
Get these 6x9's:
http://www.sonicelectronix.com/item_...Fdq6wAoda***hg
Get these 6x9's:
Ok so I have been shopping and I'm clearing going to go over the budget I set. Oh well...What I have so far:
Fairing Lowers
I added fairing lowers with speaker pods that angle up a bit.
http://www.ebay.com/itm/252491126876...%3AMEBIDX%3AIT
These are great quality and fit the lowers perfectly. Plus it was way easier than making something.
Need some help with speakers...either of these?
Hertz Audio ECX 165.5 6.5" Energy Series 2-Way Coaxial Speakers
Amps
Rockford Fosgate PBR300X4 Punch BRT 300-Watt Ultra Compact 4-Channel Amplifier
Soundstream ST4.1000D Stealth Series 1000W Class D 4-Channel Amplifier
I'd like to have bluetooth but its not a deal breaker.
Rear Setup
So far I have these and will pickup some speaker lids. Should I get a dual lid or will one do it.
Infiniti Kappa 693.11i
Fairing Lowers
Amps
Rear Setup
If you have speaker boxes in the lowers you won't need the adapters from eBay. Those adapters are for mounting speaker in the lower glove boxes. These are what the speaker boxes look like.
With no wind protection form a fairing you will need some very loud speakers if you want to hear them going down the road. Pro Audio is the way to go but would need separate tweeters or horns for highs. Other than in the bags I don't know where else they could be mounted.
Are you thinking about purchasing lowers or just talking speakers on the roll bar?
If you are going to build your own dash, check out the pics of Bunkers bike with horns molded into the glove boxes. Something to think about if your handy with glass.
