That is a line out converter with adjustments not a line leveler. The BT line leveler has built in filters to target certain frequencies that help flatten the EQ of the stock Rushmore HU. Stick with the BT line levelers.
Ok, for once please just take the advice and go with the BT LL355s and dont touch the ***** on it. Right now these are the easiest/best choice for Rushmores and they just plain work. With the LOCs you will have to pray you get a good flash and HD is making it harder by the day.
Agreed. Frisco - The guys here including myself have spent a ton of time and money testing out products that work well on our bikes. Not only that. Some of our vendors here have done the same thing. Hours and hours of research. If you have a product that you have tested that works well. By all means present it to the group. We will vett it, test it and add it to the list. The Biketronics LL's are solid.
