Dynamat Batwing Install - Rushmore
#51
#52
You're correct as far as using the various products in an automotive application.
When I was installing the Dynamat in my 2014 batwing I did a very unscientific "tap" test with each piece I installed. When tapping the outer shell of the fairing with my finger, you could definitely hear some resonance. I would add a piece of Dmat and that specific area would respond with a dull "thud". The "un-matted" area, immediately adjacent to the "matted" area would still have some resonance. When I was finished with the Dmat install, there was NO fairing resonance.
The same was true with the inner fairing, so I also added Dmat to it.
Am I happy with the results? Absolutely.
All told, the extra weight added to my "completely covered" fairing was 2 pounds & 9 ounces. If the weight affects my bike's performance, I'll add cams and a big bore kit. lol
#53
#54
It depends on what speakers and the amount of power supplying them. Having the Focal KRX2 (2ohm) speaker powered by the BT amp pushing over 300watts the Rushmore outer fairing with the big hole in it (vent) sounded like it was going to shatter into pieces without the Second Skin Damplifier installed. I can assure you I could hear the difference between 1 sq ft and 4.
#55
If I am going to go through the process of putting sound deadening material on the inside of my fairing I guess I don't know why I'd half *** it and cover only parts of it. What am I trying to save? Time? $6 in Dynamat? a pound of added weight on an 800lb motorcycle?
To each their own but if I'm going to go through the process, it's going to be covered completely.
#56
First thanks for taking the time to do this. Excellent job! I'd love to be next in line for those stencils and I'll be happy to make a copy and send em down the line! Who wants to send me a set? I gotta get started on this thing before Tailwind and Haze start calling me names again lol!
-FW
-FW
#57
-FW
-FW
#59
-FW
-FW
#60
