Tuning Questions & Software Version 1.17.1 (Rushmore)
Old 01-22-2017, 08:13 PM
Bertk's Avatar
Bertk
Bertk is offline
Originally Posted by WestTexasRanger
Where can I download 1.20.1?
The Harley site only shows 1.20.3.
Here you go.
WestTexasRanger (01-22-2017)
Old 01-23-2017, 01:43 PM
WestTexasRanger's Avatar
WestTexasRanger
WestTexasRanger is offline
Default 10 Volt Variation when bike is running
Just got the 1.20.1 update installed (thanks, Bertk).
1,000 Hz Test tone - 0db
Bass & Treble set to the middle position (Boom Box 6.5)
Fade set to Front
AVC set to OFF
Testing with a DMM, I set the amp gains at 25 VAC with the bike "Off". Started the engine and it goes up to 34.8 VAC at idle. (YIKES!)
Any suggestions as to what's going on?
Just tried setting Bass & Treble to ZERO bars showing - Still getting almost a 10 VAC variance.
HELP!
Old 01-23-2017, 03:36 PM
WestTexasRanger
I think I found the answer to my problem with the voltage variation:
https://www.hdforums.com/forum/audio...t-started.html
If there's something else contributing to my problem, please chime in.
Old 01-23-2017, 06:08 PM
tesnevo's Avatar
tesnevo
tesnevo is offline
As others stated buddy always set the gains with the bike warmed up and running. Keep in mind The voltage output varies from start up to warmed up so warm her up.
Noting else will be contributing to the spike.
Old 01-23-2017, 06:47 PM
Bertk's Avatar
Bertk
Bertk is offline
WTR, Tesnevo makes a good point. Before starting the bike to adjust Gains fully charge the battery and check it with the DMM. It should read around 13volts DC. Take a look at the volt meter in the fairing after starting the bike and see if it's reading normal output, just over 14 volts.
dgoode01
Audio Systems
04-17-2017 09:44 PM
No U Glider
Audio Systems
11-25-2016 07:58 AM
Bertk
Audio Systems
05-13-2016 10:42 AM
pp6000v2
Audio Systems
08-20-2015 08:23 PM
gjcusa
Audio Systems
01-03-2014 12:01 PM
Quick Reply: Tuning Questions & Software Version 1.17.1 (Rushmore)
