Bridged 4 channel amp ..
Old 01-07-2017, 03:55 PM
pglider's Avatar
pglider
pglider is offline
[QUOTE=WestTexasRanger;15818167]Thanks! I'm back on the same page as you guys. I'll try not to blink, less I be left behind, again.[/QUOT. Gotts be a better way than multiple cables y adapters?
  #52
Old 01-07-2017, 05:03 PM
Tailwind's Avatar
Tailwind
Tailwind is offline
Found some similar Y adapters at the local audio supply shop and now playing some serious panty dropper "stereo" shix boys!!!!
Actually not that big of a difference, unless it's that song that dances around the various stages by design. But it's all about these numerous little details that add up to make a difference.
Made it work to feed 2 amps bridged in stereo from one BT355 LL via the Y adapter/coupler (pictured in previous threads), 4 18" Y RCAs (1 male to 2 female), and 8 male to male couplers at the amp inputs. Eliminated about 10' of shix.
The way to improve upon this setup is to somehow find good quality 18" to 24" 1 male to 2 male Y RCAs thus eliminating the 8 male to male coupler connections at the amp. Kind of a hillbilly set up for now but the bridged "stereo" mission is complete for about $25. Much cleaner install, regardless.
Thx for the info exchange brothas!!!!! Big thanks to Flying Broke for pouring gas on this topic that I am a total caveman on.
T.
pglider (01-07-2017)
  #53
Old 01-07-2017, 05:21 PM
slyedog's Avatar
slyedog
slyedog is offline
Way to go T. The only way to go 1m/2m Y is to buy male male adapters for the female side. No one makes a quality male to 2 male y splitter. A lot of you run lowers but I am throwing a wrench in this for a minute. I would only be concerned with the fairing being in stereo. Let the rest just be. You wont notice it much if at all and really will save on a lot of interconnect cables. Also at the end of the day, I would also plan setups that would not require having to bridge the front stage. Easier said than done, but I felt I was wasting power on minimal gains.
  #54
Old 01-07-2017, 05:57 PM
matt76cmich's Avatar
matt76cmich
matt76cmich is offline
Yup, made an amp decision today with the new build and no bridging will be needed now..........maybe lol
  #55
Old 01-07-2017, 06:06 PM
WestTexasRanger's Avatar
WestTexasRanger
WestTexasRanger is offline
Which amp?
  #56
Tailwind's Avatar
Tailwind
Tailwind is offline
Great damn points Slye!
T.
  #57
Old 01-07-2017, 06:10 PM
matt76cmich
All in due time. Once I have everything installed I'll have a run down of everything. Things are getting tested out before they get sent to me. I'll have more on my build thread soon.
  #58
Old 01-07-2017, 06:21 PM
Outkast6991's Avatar
Outkast6991
Outkast6991 is offline
in the fairing or bag? It must be a crazy setup cause I just got done testing out your hand me downs and I'm in love! Thanks again man
  #59
Old 03-19-2017, 08:48 AM
marvincbr's Avatar
marvincbr
marvincbr is offline
Originally Posted by WestTexasRanger
There are two ways to bridge this amp for two speaker operation.
One is for stereo (for our motorcycle applications) and one is for mono (when running 2 sub woofers for example).
The attached detail from the JL owners manual show you how to wire it both ways. Please note that the Channel Selector Switch is a different position in each application.
Using the the lower wiring diagram:
...Set the Channel Selector to "4"
...Install RCA "Y" adapters as shown to connect from your radio (or Line Leveler) to the amp
...Wire the speakers as shown.
Voila! You now have front speakers running from a bridged amp in STEREO.
By the way: Led Zepplin's "Whole Lotta Love" would suck in Mono!
I'm relatively new to this area of the forum and have recently purchased a new set up. I have the DD D4 amp that I planned on bridging to run a set of AW 6.5 and AT28 in the fairing. I'm trying to follow this as best I can, but am wondering if the source has 4 outs, why not use the RL and RR to the amp instead of splitting the front?
  #60
Old 07-12-2017, 06:15 PM
HogPilot54's Avatar
HogPilot54
HogPilot54 is offline
Talking
Never mind. I figured it out.
rochman
Audio Systems
02-10-2019 07:58 AM
jory434
Audio Systems
15
10-22-2018 03:13 PM
pktrusty
Audio Systems
06-09-2016 10:51 AM
Angelsbass
Audio Systems
45
03-31-2016 10:46 AM
Da Shadow
Audio Systems
10-20-2013 01:48 PM
Quick Reply: Bridged 4 channel amp ..
