EQ settings needed for Kenwood 998
I am unable to search for EQ on this forum because it is less than the required three characters. And I read through 2 hours of post and I could not find it.
I have seen pictures of EQ settings in threads of the 998 and I cant find them now.
Can someone please tell me what settings they are using for each band in the EQ section or a link to a post would help?
Using Kenwood 998, BT4180, BT 7.1 front fairing, Hertz 165 in the lowers.
Thanks
Thanks
Thanks
Thanks
To get you started give these setting a try.
It helps to keep notes by printing out page 18-23 from the manual
Note: Set or readjust the gains on the amp after making these settings.
(*) Set to your liking
Select the Source you are using to listen to music on!
Starting on Page 18
Set Drive Equalizer to OFF
Set Preset Equalizer to USER
* Manual Equalizer - Adjust GAINS to each Band:
Band1 = 3
Band2 = 2
Band3 = 2
Band4 = 1
Band5 = 0
Band6 = 0
Band7 = 0
Band8 = 0
Band9 = 0
Band10 = 1
Band11 = 2
Band12 = 3
Band13 = 3
Q Factor: 1.50
Bass EXT: OFF
Pro Setup
DSP Set: Through
Car type: OFF
Speaker Settings
* Front speaker location: ON DASH
* Size: 6 1/2in
* TW: Medium
* Rear speaker location: Rear Deck
* Size: 6 x 9
* TW: Large
X/Overs Front (Using these setting set the amp x-over to All Pass, Flat, or Full)
* FC: 80 to 100
* Slope: -12 or -18
Gain: 0 (Or depends on the Amp) – (Using a Biketronics Amp set this to -1)
* Tweeter FC: 4khz
* Tweeter Volume: 0
X/Overs Rear (Using these setting set the amp x-over to All Pass, Flat, or Full)
* FC: 80 to 100
* Slope: -12 or -18
Gain: 0 (Or depends on the amp) - (Using a Biketronics Amp set this to -1)
* Tweeter FC: 4khz
Gain Left & Right: 0
DTA Settings
Preset Position: ALL
DTA: All of these should be set to 0
Channel Level: All of these should be set to 0
Sound Enhancements
* Supreme: ON or OFF
Space Enhancer: OFF
Sound Realizer: OFF
Sound Elevation: OFF
Volume Offset: 0 (Using a Biketronics Amp set this to -7)
Bass Boost: OFF
Loudness: OFF
Balance: 0
* Fade:
EQ should look like this.
Last edited by Bertk; 04-02-2017 at 08:51 PM. Reason: Changed FC / crossover settings
Budda109 (12-28-2016)
Note: I just updated the FC / crossover settings.
