Power and ground connection for 2 amps
Power and ground connection for 2 amps question
I am getting ready to install 2 amps in the fairing of my Rushmore SG, an Arc 600.4 and an NVX MVPA4. My question is would I be better off putting distribution blocks close to the battery and runnig the 4 wires to the fairing or running single 4 ga wires to the fairing and splitting to 2 8ga each for power and ground? Maybe I am over thinking it and it doesn't make a difference either way but I'd like to know for sure before I do it incorrectly. SF
You can also go with four 8ga wires. A lot depends on what will fit the best.
old v twin (11-20-2016)
If you go from a 4ga to a 8ga you would use a 60 amp fuse at the battery and a 30 amp fuse to each amplifier at the distribution fuse block. I'll post some pics in a little later.
Not over thinking at all. This is important. I just got through do this on the 08 SG. I used two 4ga wires from the battery to the fairing. The positive is fused at the battery. Then used a fused distribution block to go from the 4ga to two 8ga wires. And used a ground block that goes from 4ga to four 8ga wires.
How do you have the Kenwood connected? My 998 is connected to the BT handlebar control module for power and ground.
