Amp Help
Happy Halloween!
The real treat was from CVOJOE who offered me a sweet deal on an ARC Moto 600.4. Thanks to Bagger Bill- SBD lids & JL 770's, Tesnevo who sold me the JL ZR 650csi's and CVOJOE for the the amp steal. Thanks to all who have offered advice and guidance to a newbie. Great bunch of people.
I believe I still need BT Line Levels and BT speaker mounts for the ZR650's, as well as a wiring kit.
Budget is kinda blown but I got everything I need for a nicer system than I had hoped for originally and I won't need an immediate upgrade, hopefully!
I'm sure Ill be asking for more help as the install happens and I'll post up some pic's.
I made it to the dealer - $44.50 later I have a Fade and it appears they didn't F anything up!
You can either get a wiring kit or put one together yourself. KnuKonceptz makes good products and sells wire in lengths.
8ga power cable, 7" or red and black
8ga battery ring terminals
8ga Inline fuse holder with fuse rated for the 600.4
16ga speaker wire
16ga speaker terminals
2 pair of these RCA Cables.
I look like everything coming together nicely. You will want to make sure the Speed Volume of turned OFF with the new system installed.
16ga speaker wire
16ga speaker wire
Arc owners manual suggests 4 gauge power and ground is that overkill? You reference 8 gauge.
Manual says amp will take up to 14 AWG speaker wire. Am I okay with 16 or is bigger always better?
Is there a suggested type of quick connect I could splice in the speakers lids wires to facilitate bag removal? Picturing the splice / connector under the seat out of the weather...
Do I just wire the amp ground to the negative battery terminal?
No U Glider (11-08-2016)
Need a little guidance... The Arc Tech is telling me no need for line levelers.. just need a wiring kit and another wiring kit to adapt to 4 speakers and everything will be plug and play. I ordered RCA cables and he tells me I don't need them. With the limited knowledge I have, plug and play is appealing but I want the max out of what I have bought. Speaker and power connections to the amp seem pretty straight forward, but I'm unclear how I get signal from the head unit to the amp and what is involved in installing the Line Levelers. I have the Arc plug in that adapts to the input and allows cable RCA plug-in.
Thanks again for your help...
1. you can get the Arc 2014+ HD Adapter harness, which will plug into the the HD speaker wires and those will plug into the input wiring harness that came with the amp. The amp input wiring harness has some inline resistors that lower the voltage eliminating the need for line levelers.
2. Buy the BT line levelers that have the 2014 + speaker connections for the input and RCA connectors for the output. Use a set of RCA connectors from the BT line levelers to the Arc Input harness that has the RCA connectors
No U Glider (11-11-2016)
I have attached a pic of the ARC input hookup wiring. you can add a set of RCA splitters to hit channels 1-2 and 3-4 or you can tie the front and rear speaker input wires together to hit channels 1-2 and 3-4
