Rushmore stereo help
Originally Posted by Fatherwayne
No stupid questions here. I've been all over these forums and I just learned something new thanks to Tailwind!
-Wayne
-Wayne
cjwanner:
Good to see you are making progress.
To install the software you will need an empty 8gb or larger thumb drive.
Place the downloaded zip file on the desktop
Right click on the zip file and select Extract All
Open the extracted folder just created and locate the "swdl_boombox_6.5GT.iso" file
This is the only file you want to copy to the thumb drive
Then take the thumb drive and plug it into the USB connection on the bike
Turn the ignition to Acc and click yes to install.
If any of these steps fail, let me know.
Originally Posted by Bertk
cjwanner:
Thanks buddy. And thanks for the pics. Is that something I buy (if so, where? ) or something I build?
They are called F.A.S.T Rings if u GTS (Google That Shix) and if u don't have any luck just let me know.
T.
I bet u could make them pretty damn easy but if u just want to slap them in I have seen them online at a few spots including Amazon. I have a local Car Toys chain a mile away and the have boxes of them. About 23 bucks. They are called F.A.S.T Rings if u GTS (Google That Shix) and if u don't have any luck just let me know. T.
Originally Posted by cjwanner2000
These make enough difference to be worth doing? Any problem with them getting wet in the fairing?
As for the moisture concern, would not be concerned but at the same point I would try and get ur fairing to seal up a but tighter as there really aren't many things under the hood that are designed to flourish in water.
T
