I want a more powerful setup
So here goes phase 4 of the audio upgrades, thanks to you guys!!!
I'm wanting to go to a more powerful amp (currently arc 600.4) and 4 speakers that can handle more power. (Currently 2 focals krc165 in the tour package JL audio zr650 csi in the fairing)
I want more power and louder.
Yes it sounds great and clear now but I want more out of this.
Head unit will stay (2014 FLHTKSE With 6.5 CVO UNIT) along with the btll.
Is there a bigger amp option with these speakers or should I just do bigger amp and new speakers?
Don't need a bigger amp. The Arc 600.4 is one of the most efficient amps out there for our bikes. Just doesn't do well with the 89db JL ZR's. You need some higher sensitivity speakers in your fairing if your looking for more loudness with the 600.4. It's all about the speakers matching the amp bro!!
Higher sensitivity speakers will get you more volume from that amp but chances are you will lose low end. If you keep those JL's bridge the Arc 600.4 to then and add a small amp bridged to power your rear. The NVX mini fits well on the BT bracket and is only a 150.00 investment. Or you could do a combination of pa speakers and horns up front of the arc and some bass friendly speakers bridged off the NVX in the back. I'd start with a small second amp and see if the additional power is enough.
That!!
As Haze said. Bridge the 600.4 to the ZR's and add the NVX for the rear. That will get you more power to the ZR's Or go with higher sensitivity speakers and horns up front. Those ZR's sound good in the lids too!! Ask me how I know.
thats whatvi will do then. Probably mount the NVX in the trunk. Not much room left in the fairing with the huge JL crossovers, line leveled and the arc amp.
since I'm going to trunk mount the amp should I go with something a little better than the NVX? I don't mind an amp taking a little more room but not much more. I was thinking of the kenwood kac-m3004. I installed thin in a buddy's bike running a set of hertz and it's an amazing amp
lol, yea I know you love those JL's.
