Boom stage 1 amp dealer flash question
Originally Posted by grumble
Boom amp. When going third party there are many ways to skin a cat. Digital technician should be used to flash the head unit to tell it that it had 1 amp and 2 speakers for his setup.
T.
The "0 amps 8 speakers" was a setting in a much older version of Digital Technician. RF now recommends that if you don't want to use line levelers, just flash to the proper number of amps and speakers you are installing. This adjusts output level and flattens the EQ curve. If you are using line levelers, you'd set it to 0 amps because it keeps the whacked out EQ curve/levels and the line levelers take care of that.
Shix, everything about me is getting old!!!! Lol!
Thanks for the info!!! If you happen to have the publication regarding this recent RF flash strategy, do u mind posting it under a separate thread title so folks can head down the proper road when not using the BT355 Line Leveler?
T.
Good info!!! Never got the memo as I'm on one of those "much older" 2014s u speak of.
T.
T.
Originally Posted by Fatherwayne
T... Are we accepting this as fact against everything Biketronics says? No offense to the poster but this goes against everything we know to be true up until now. Flattens out the curve? Really? If this was now the case wouldn't it be all over the forum by now?
Now there r plenty of folks that are running without the LLs, but what are they doing to get the best sound possible? The competition folks are absolutely running DSP. J&M is running DSP technology but the programming is proprietary to JM John. The Fix has entered the picture as well. What about the folks on a Rushmore w aftermarket tunes that have no idea what a LL or DSP is? Substandard sound?
For me LL is simply the best course of action for me and many others, for several reasons, up to the point where an aftermarket waterproof big screen HU w full functionality enters the picture.
My ears like the result that the LLs produce. Simple, inexpensive, plug and play, compact, and they work pretty damn good all things considered.
T.
The 2 amp 8 speaker flash is THE best flash that you can get now and also provides the flattest EQ curve without the use of a DSP. You WILL loose all fade and tone control though.
95HDGlide
Audio Systems
05-09-2018 02:27 PM
