Help!!!!
Help!!!!
I have a 12 street glide, started with pbr300x4 and punch 6.5" speakers in lids and fairing. Plenty of volume sitting still and at higway speeds but starts to distort quick-15minutes like amp is getting too hot. Happens quicker when riding than sitting in shop with bike off. Have the fosgate wiring kit and heatsink also. So I have hertz speakers in my truck and decided to buy a pair of hcx 165 for the fairing(since that's pretty much all I hear when riding. and just ordered a rz42000d to power them and the fosgates in the lids. Im also just using the factory radio due to looks-I like the stock look with stereo equipment. Am I just going down the wrong path? I feel like between reading everything on here im just confusing myself. Any help is appreciated. And as a side note with the problems im having with fosgate amp, I did have local stereo shop check my install and wiring is correct for the amp-we are all boggled that sitting still in garage everything sounds perfect but starts distorting down the road. and once I stop again its still distorted.
This is probably the most crucial step when installing a system. Always make your final adjustments with the bike running. As noted above you are headed in the right direction.
I would suggest using straight aux instead of the adapter. As far as tuning process goes if you do not have any meters. I would suggest digging through a few of the help threads on here. There are several very well written in depth threads on how to tune.
The dongle isn't necessarily a bad thing but I will say when using one you really need to be in tune with your system and music source. Also having a good ear for hearing distortion especially while riding is key but it's not something everyone can do. Distortion is the #1 killer of any audio system.
Last question for you all and I should be good to go, I received the rz42000d, my radio has two speaker outs not four, do I just splice into the wires for hi level input so both left sides of amp are left of radio and both rights the right of radio? Didn't know if that would work or mess up the amp
