Sound deadner
Sound deadner
Since I am installing the BT brackets I figured that I needed to put sound deader on the inside of the fairing. I ordered 10 sq ft. (I know way more than I need but smallest packaging available on amazon). I read about the cheaper alternatives but decided on second skin damplifier pro. I have never worked with the stuff so any helpful hints from the experienced would be appreciated.
I have been thinking of adding some of the same material to my inner fairing. I am getting a lot of vibration from my tunes. Also getting the same from my lowers too. I am not blasting the tunes, just 1/4 to almost half up on the volume bars. Running a BT2180 and corresponding BT 7.1's in the fairing and 6.5's in the lowers.
I have ordered it but have not received it. My plan is for a winter project. The space is already tight and I was not aware of the thickness of the pro version just going by what others recommended. I got it on Amazon so hopefully I can return it.
The damplifier pro showed up today but this stuff is pretty thin and not what I expected. It is heavy and very stiff so installing it is going to be a bitch. Not sure how to tell if it is really the pro stuff. It is one sq ft sheets black and embossed with the second skin logo. Ten sheets weighs about 5 lbs. Hoping there is enough to do the bags as well but I doubt it.
