Help tuning my CV B52
09-02-2016, 12:03 PM
Hey guys. I posted a thread a few days ago asking for advice on which components to buy for my '14 SGS. I ended up going with a CV B52 amp, focal 165 KRC's, BT line leveler and BT brackets. I got most of it installed last night. Do you guys have any recommendations on how to go about tuning this? I was figuring to set the gains with a DMM and then adjust bass/treble from there. It appears the gain on the amp can only be adjusted by the remote ****. Is this correct or am I looking at it wrong? Should I be in HP or flat setting? Anything else to be aware of? Thanks for any help you guys can give.
09-02-2016, 03:02 PM
I have a CV B54, it has gain controls on the side. I think the remote is just a option.
09-02-2016, 03:05 PM
Quote:
All I could find on mine is sensitivity and frequency.
09-02-2016, 03:24 PM
09-02-2016, 03:26 PM
Quote:
Originally Posted by haze324
Input sensitivity = Gain
O ok. That makes a little more sense thanks. I figured that would be the same as on the PBR for the hi level input to turn the amp on.
09-02-2016, 09:34 PM
Ok not sure what I'm doing wrong here. I downloaded the test tone onto a thumb drive and the HU just keeps saying reading....
09-02-2016, 10:22 PM
cjwanner2000
Is the file a .mp3? It should look something like this 1000Hz 0dB.mp3
09-02-2016, 10:27 PM
Quote:
Yep it says MP3. I downloaded it from ultranutz' sticky. Hooked the thumb drive up and it won't read
09-02-2016, 10:34 PM
cjwanner2000
Try another thumb drive with only the test tone on it. The thumb drive has to formatted to Fat32.
09-02-2016, 11:05 PM
It's a brand new thumb drive never used before. Let me see if I can figure out the fat32
