short antenna in fairing
Hi was hoping someone can help.I have tried all kinds of fairing antenna's and to be honest they suck i had a short antenna that worked great and want to put in fairing but not sure how to connect it to radio?The short antenna threaded into the antenna cable on the back of bike how would i do this in a fairing? need a threaded connector to attach to antenna the plug into radio?Someone said there is a how to but cant find it.
Thanks
Thanks
I know that lots of folks have tried lots of antennas and so have I. Powered, unpowered, fairing and non. Almost all have some negative effect over the big whip HD provides. After trying several I have found that the free mod re-routing the OE antenna along the frame and along the seat works as good as any. JMHO
https://www.hdforums.com/forum/touri...e-antenna.html
There are some YouTube goobers showing how to do it also. I ran mine next to the frame and nylon tied it in place so it doesn't cross under the seat and isn't in the way when you take the seat off.
