I bought a SMD DD-1 plus. Question/help.
So I went ahead and bought a SMD Distortion Detector DD-1 PLUS. Got too good of a deal to pass on.
Since I've got the 2014 CVO 6.5 head unit going to 2 BT line levelers then to an arc xdi 600.4 running 4 focal KRC's 165 speakers, what am I looking for in respect to where the voltage/hz-kHz should be set at each point?
Meaning from ll's to amp then amp to speakers?
Next u will want to test where the amp is gonna send dirty sound to the speaks. After u determine that max gain setting u will want to note the vac and from there dial in the gain for the speaks that u r using. Since those speaks have a max rating of about 160w and an RMS of about 90, u know for sure u probably don't want to have the amp gain set higher than 24.5 vac or 150w.
In a nutshell, the DD1 is determining max clean sound so never exceed those values. The DMM will get u the desired watts but never exceed the DD1 values.
And never ignore what ur ears r telling u as those damn things really r your best tuning tool.
T.
The following 2 users liked this post by Tailwind:
CVOJOE (08-11-2016),
Rockford Fosgate (08-11-2016)
Don't have android, I've got an iPhone but will look to see what I can find. It does come with a disk and has many different tones. Do I just use one or all of the tones on loop?
