Kappa 62.11i Adapter Rings
I'm having a hard time getting adapter rings that will fit the Kappas. I first ordered the 6 1/2" adapter rings that Rickford Fosgate sells and they were way off. I then ordered a set made by Dragonfly Cycle Concepts and they are closer to fitting but I can only get a couple holes to line up and the rubber ring on the speaker is very close to rubbing on the adapter. Any suggestions as to what adapter will work?
Yup, go with the Metra.. Just installed them Sunday, fit perfect..
careful with supplied screw on the bottom..it will dimple the front of the fairing if you screw it in to tight..
https://www.amazon.com/Metra-82-9601.../dp/B00JKXSJTM
here they are shipped for under 12 bucks
