I am running 1.9.2 with awesome results as every time I try 1.9.0 the radio volume surges like hell. I have tried the Rushmore radio reset many times as well.
Hot the download and hu reset done. Definitely need to readjust my bt355 LL. When I do this where do you guys recommend I put the bass and treble at for best results
Software version works best with a stock flash. Has the HU been flashed by the dealer?
When you adjusted the LL the first time did you use a DMM or by ear?
Did you adjust the HPF?
Good. Leave the HPF as is. After tuning with the LL's the gains should be close to the 12:00 as shown below. If you want to check the voltage at the speaker outputs on the amp with a DMM they should be 24.50 VAC with a 1000Hz 0dB test tone volume 15. Fade set to middle along with bass and treble as shown below.
