in depth setting question
im probably gonna be all over the map with this but here goes. got my new wires form knu and still had the miswiring message, installed a new HU and everything is working fine. it had been awhile since i messed with the settings on the amp the amp and HU but while i was chasing down the error i changed all kinds of stuff and messed with every button or **** in the amp. Current set up is b2 amp,kappas and kenwood kdcbt420. on the amp should the x over be on hp,flat or lp, i believe i had it on flat before. i took my flash drive out and used the mp3 gain tool that bates posted about to get all my songs the same volume level, the sound was wreaking havoc when tuning due to one song being loud as hell and the next not. next question i guess i more involved. the frequencies for various settings . i go to eq pro and get settings like mid ctr frq with 2.5khz(for example) and lower. me not knowin anything really i just go thru all the settings and tweak each one untill i get a sound i like which usually takes me forever. are there any frequency levels i should avoid. or is my amateur way safe lol, bass mids and highs will be the death of me..it seems as if i cant get the sound i had prior the head unit messing up. if it helps i can post every setting for all the different categories
Those basic settings I can manage..for example. Eq pro has bass ctr frq 60 to 200hz bass level +-8,bass q factor100-200 bass extend off and on, about the same for mid, treble is just level and ctr frq, then there lpf sub settings that go from through to 160hz,hps is through to 150hz,and sound reconstruction.. I don't expect anyone to give recommendations for every singlr thing lol but when I see those factors I have no idea if100hz on one setting is bad or good on another
I'm not sure if it'll help but I can go thru everything and write it down.. Maybe I'm thinkin too far into it but I know I don't have top of the line equipment, so I'd like to keep it workin untill I cnn upgrade.. I always question my work, I'm just a cheap shade tree fixer upper.. I listen to heavy metal kinda stuff which has alotnof heavy distortion sounds.. I myself find it hard to tell between that and speaker distortion lol
Xover and FREQ correct, I cant tell you where to set amp gains. A test tone and dmm or your ear will be the judge there. Remember once it gets loud and you get that feeling to not know if you should go further, trust that feeling. Turn the dial SLOWLY.
I wouldn't necessarily worry about where the gains "should" be. Adjust them by ear till you get distortion then back them down. It is what it is.
