3.5 mm aux input broken
It's a $5 fix if you do it yourself. You can order the jack here: https://www.tindie.com/products/nift...ll_prod_search
When you get it, just heat the solder and remove it from the board then solder it on yours.
Spray some electrical cleaner into the input port and work the 3.5 plug in and out a few time and respray with electrical cleaner. Let dry and give it a try. It won't hurt to repeat this a couple of times. Sometimes this is all it needs.
