Arc Moto 600.4 RCA Input range issue is lower than my Head unit output
Hey Guys
The head unit I bought is a Sony Mex-MT70BT and puts out 5 volts pre-amp out.
Looking at my Arc Moto 600.4 spec sheet, it shows a max volts of 4 volts
It reads: RCA Input Voltage -200mV-4.0V
With my head unit putting out 5 volts, will this affect or hurt anything or cause tuning issues on this amp???
Thanks guys for all your input,
Full steam ahead as planned,
I went with the Hawg wired radio install kit And controller.
Most stuff should be here in the latter part of the week, The only thing that may hold off till Monday is the 8000 series Stinger RCA cables.
I'm not really sure if those make a difference, over just a good set of RCA connectors, But after listening to Haze, Gann, Sly and UltraNutz, I decided that I'm not going to let a $50 set of connectors compromise a $2000 system
It's all good and thank you guys once again
smlosches@yahoo.com
Audio Systems
12-20-2018 05:59 PM
