HELP!!! Infinity Kappa 62.11i and Power Accoustic RZ4 2000D
I installed these speakers and amp, along with a Sony HU. All was great for awhile.....now randomly the left fairing speaker sounds blown, and even cuts out once in awhile going down the road. I put it in the garage and have pulled the fairing, and can't get it to do it. I even let the bike idle and can't replicate it. I have checked that all my connections to that speaker are tight. What the hell do I do guys???? I know something with the fairing must be causing it but I am lost. Would an LED BULB cause some kind of interference to cause it???? That's the only thing I have changed. Help me out guys....thanks
Bro, you may not believe this as I am having a hard time as well but I had some pretty damn durable speaks recently installed in my fairing and after a long tuning session it was finally time to clean up the wiring with zip ties and put the hood on. After securing the wires I did one more sound check before putting the hood on and the right speaker sounded totally blown.
Long story short, my hidden antenna that wraps around the inner fairing was too close to the damn speaker raising all kinds of hell on it thus the extreme distortion.
Just lake sure u don't have any possible electrical wires in direct contact with or too close to the speaker itself.
Strange deal but could be possible for your situation.
Just a thought.
T
Just a thought.
T
Sounds like it only does it when the the bike is moving. That normally means loose connections. Now you have to find it. It could be anything from ground connections to Those pesky RCA's! Change the affected speaker and see if you still have the same issue going down the road. I think when T had his antenna problem the bike was sitting still.
