I have a radio I bought used. Was told it worked fine and for the most part it does. But the AUX Jack cuts in and out. Is there a place to send it to have it repaired. its P/N is 76164-04.
Thanks
Jeff
Thanks
Jeff
Pickup some electrical cleaner and spray it into the AUX jack a few times. I may just need to be cleaned out. Let it dry and give it a try.
and let it soak a bit, then insert and remove an audio jack a bunch of times.
If the above doesn't work, and you aren't electronically inclined to replace it youself, get it repaired at Iron Cross Audio. While they have it, have them add Bluetooth to it. They are great to deal with!!
