Blown right speaker again???
Hey guys i am currently running the BT 4180 KRC 165 in front fairing and the lids are the HCX 690 i recently changed the lid speakers because of thee
right rear speaker was blown and they replaced with a new set thinking I had a lemon from the start now the same speaker is blown the right rear HCX 690 what do i need to test or check as i think there is a problem with the amp?? Need help i am riding a 2015 SGS and i am running the 1.19.0 software.
Originally Posted by SCHATZY
Would a bad connection blow a speaker?? When i installed the new speakers and did the sound check it was all good then we did a couple of long rides still good and all of a sudden yesterday the right speaker sounded blown.
What are ur gains set to on the rear BT355?
T.
Just confirmed it is the speaker blown i remembered when i did the wiring when i installed the amp i had a hard time with making a good connection at the amp on the right side just thinking if it is a poor connection at the amp and it cuts in and out would that blow a speaker?? I am going to take the hood off and check the connection and advise when i am done thanks.
So grab your Line Leveler for the rear channel and let us know what the settings are using a clock as the reference to where the little arrows are pointing. 2 o'clock? 3 o'clock?
Also, are the HPF settings on the top of the LL set at the default reference lines?
The gains are on the side / end of the LL if u are unfamiliar.
This will help troubleshoot.
T
T
