Disappointed infinity Kappa 62.11i and Power acoustic RZ4-2000D
Old 08-16-2016, 04:25 PM
Riveroger's Avatar
Riveroger
Riveroger is offline
Originally Posted by Babyboy
How did you set The output voltage of the PAC SNI 35 to make sure they were the same?
Are the frequency switches on the amp both on full pass or High pass?
Edit
If the voltage is different from the LOC to amp you will have a different tone coming out of the amp to the speakers possibly causing the difference in sound even if the output voltage of the amp is set the same the input voltage to the amp via the LOC being off a little will cause a sound difference
I just turned the pots like the manual said found the sweet spot but couldn't get the front channels to sound decent. Can I it put a DVM on the outputs of the line converter? What would be the process. Thanks..
  #42
Old 08-16-2016, 07:15 PM
Babyboy's Avatar
Babyboy
Babyboy is offline
Yes you can use a DMM on the out put side of the LOC and adjust while playing a 1k test tone.
POSITIVE lead on the center rca pole and negative on the outer ring
I am trying to remember what the output voltage on the output of the LOC I used on the last set up that was similar to yours.I want to say it was around 2.5 VAC
I have the numbers in my notes at home and I am stuck at work till 10pm.
  #43
Old 08-16-2016, 09:16 PM
Riveroger's Avatar
Riveroger
My job really cuts into my day too. I am going to measure the rear channels which sound great and set the front channel to the same voltage. i report the results.
  #44
Old 09-13-2016, 03:04 PM
Cheesehead_13's Avatar
Cheesehead_13
Cheesehead_13 is offline
Install is complete
Bike was an 01 street glide with stock Radio Sounds HU.
PAC SNI 35 line converter
Arc is 125.2 bx amp
Rockford fosgate 6.5 speakers
TESTING EQUIPMENT USED
SMD DD1
BLUE POINT 586 DMM
Using a 1k -10db at 3/4 volume was the happy spot on the head unit (not showing any distortion)
The line out converter was set with same test tone with 1.01 volts (11oclockish) before showing any distortion.
Amp was showing distortion at 20 volts with a clean input signal. I wound up setting the amp at 17.3 vac which was 75 watts rms per the manufacturer.
Note :When Using a stock Radio Sounds HU the Arc 125.2 amp is just about the biggest amp you will be able to fit on top of the HU without any modifications
Is the SNI 35 now the LP3-4? If not, are they the same? How do you adjust the line converter if setting gains by ear?
  #45
Old 09-13-2016, 03:26 PM
Babyboy's Avatar
Babyboy
Babyboy is offline
I could not tell you if the sni 35 and the lp3-4 are the same just in different configuration as I have not used the LP3-4
As for setting the gains by ear I would suggest setting the LOC around the 11 to 12 o'clock position and then proceed with your ear setting.
Cheesehead_13 (09-13-2016)
zippo2
Audio Systems
16
04-05-2017 03:46 PM
jskicet
2014-2023 Touring Models
01-23-2017 05:05 PM
WB
Audio Systems
15
07-22-2016 09:13 PM
SoCal_Big_Blue
Audio Systems
24
05-20-2014 12:18 PM
mntanakd
Audio Systems
05-08-2011 03:24 PM
Quick Reply: Disappointed infinity Kappa 62.11i and Power acoustic RZ4-2000D
