Disappointed infinity Kappa 62.11i and Power acoustic RZ4-2000D
#32
Install is complete
Bike was an 01 street glide with stock Radio Sounds HU.
PAC SNI 35 line converter
Arc is 125.2 bx amp
Rockford fosgate 6.5 speakers
TESTING EQUIPMENT USED
SMD DD1
BLUE POINT 586 DMM
Using a 1k -10db at 3/4 volume was the happy spot on the head unit (not showing any distortion)
The line out converter was set with same test tone with 1.01 volts (11oclockish) before showing any distortion.
Amp was showing distortion at 20 volts with a clean input signal. I wound up setting the amp at 17.3 vac which was 75 watts rms per the manufacturer.
Note :When Using a stock Radio Sounds HU the Arc 125.2 amp is just about the biggest amp you will be able to fit on top of the HU without any modifications
Arc is 125.2 bx amp
SMD DD1
BLUE POINT 586 DMM
#33
MD shot me a message earlier and was HAPPY with his upgrade.
Just a little fyi that little amp has some nuts and sounds good
#34
Could be an issue with the line levels in. Depending on your head unit, some amps dont do well with using high level inputs. Do you have any way to test the amp with another head unit with low level outputs(rca)?
Or you could try a line level converter and see if that helps. It will take the speaker outputs convert them to RCA outs and bump up the output voltage a bit.
#35
#36
Its been awhile and I have some time to work on the bike audio. I did what you suggested and installed PAC SNI-35 Variable LOC Line Out Converter and it made a huge difference punchy bass warm sounding was pure treble too bright before. But it only helped the rear channels. I double checked polarity checked everything. I swapped the rca cables on the amp rear to front and good sounds are now in faring speakers. I know a new head unit would solve everything but i use the bike communications and have an ipod interface I want to keep. Any suggestions?
#37
#38
#39
#40
Are the frequency switches on the amp both on full pass or High pass?
Edit
If the voltage is different from the LOC to amp you will have a different tone coming out of the amp to the speakers possibly causing the difference in sound even if the output voltage of the amp is set the same the input voltage to the amp via the LOC being off a little will cause a sound difference
