PA RZ4-3000D vs SS PN4-1000D
I just replaced my 3000D with a 1000D. I was long under the assumption that they were the same amp, and indeed they are built alike with the power, speaker, and RCA's all in the same place. I set the gains on the Soundstream as they were on the Power Acoustik. I was disappointed at the volume, and increased the gain to around 3 o'clock to approach what I had before. I have no hard evidence to back it up, but to my ear the Power Acoustik sounded better. If I were to do it over I would go with the 3000D instead. Just on observation if anyone out there is on the fence about which way to go.
I had the impression with the 4.520 and the PA equivalent the PA was a but more dynamic as well... but again long time ago when I was testing
Follow Haze his suggestions. 12 to 3 o'clock is WAY too much...
set everything flat, use 1khz (93? Db if you have normalized your mp3s with mp3gain!!!!!!) and dial in.
stay a bit shy of the 150W (use 140W as max for your DDM calc for 4 ohm) and 240W ish for the 2 ohm channels.
better safe than "boom' sorry
rcpilot_971
Audio Systems
07-06-2013 04:35 PM
