Polk MM651, Aquatic AV and SS PN4.520D Setup Question
I recently upgraded my sound system. My old speakers were J&M 7 1/4"s that were swapped for Polk MM651's. On the radio side, the factory Harmon Kardon (HK) was exchanged for an Aquatic AV. I tried running everything without the amp but it just wasn't loud enough on the highway. Back in with the SS PN4.520D. The X-over setting is configured in the middle. I adjusted the gain by ear (my ears are not as good as they used to be) but I am not sure if it is where it needs to be. My music source: I'm streaming via bluetooth from my Samsung S6. My hope was this setup would be a huge improvement over what I had but it is marginally better (sounding) at best. What am I missing with this setup?
BTW - question on the crossovers for the Polk's. Aren't those for when you are running tweeters/subwoofers? Can they be taken off? Sorry for my ignorance but I don't know much when it comes to car stereo stuff. I am more of a home stereo guy...
Thanks ahead
Thanks ahead
Thanks ahead
Thanks ahead
Bluetooth is THE worst source of music you can use. Get a USB stick and download your music from Itunes. How many speakers are you running?
Gannicus,
Thank you for the reply. I am running the RCA outputs from the amp to the Aquatic. One thing I thought of last night, the cables are just some old cheap ones I had from a VCR. Maybe I'll swap those for some higher quality units. I know I've seen huge improvements switching to Monster Cables for certain use cases - thougths? I will try the USB thing. My biggest like with the Aquatic is my phone can charge while I am riding. The bluetooth was just a convenience thing. Currently I am only running two speakers. I've thought about putting some in the lids but that would require spending MORE money. I haven't gotten the wife to warm up to that idea yet as she is a bit of a tight wad. :-)
Originally Posted by wam6187
Gannicus,
T.
Gannicus,
