Focal?
Old 06-15-2016, 12:46 AM
Gannicus's Avatar
Gannicus
Gannicus is offline
Originally Posted by nick4737
Is that the outcome you were expecting gannicus?
Yes Sir. I've had all the above amps in my lab and tested extensively. The soundstream has more power and more thump. SQ difference is minimal at best. So when guys start talking about the Moto, 4180, etc., have much better SQ than the soundstream I think it's comical. Don't get me wrong. They do have better SQ in the garage with the door shut. But out in the open air you need power pushing your speakers. If you have good speakers and good EQ settings on the HU the SQ is there. All the amp does is amplify it.
You can take a Rockford Fosgate 3Sixty.3 or a Audio control Overdrive with the soundstream amp and have excellent SQ. The moral of the story is don't judge that amp until you've set it up to it's potential. The Soundstream TN4.900 and the 1000D are both very good amps for the money.
  #62
Old 06-15-2016, 05:15 AM
sponger's Avatar
sponger
sponger is offline
Now what about that ss amp against the fosgate tm400x4 amp???????
  #63
Old 06-15-2016, 11:45 AM
Gannicus's Avatar
Gannicus
Gannicus is offline
if I'm hooking both amps to a set of Biketronics Titan II speakers I'm taking the SS all day long. Again, depends on the speakers bro. But my point was if you take both of those amps and hook em to a set of focal KRC's the SQ difference is minimal. Especially if you take the price difference into consideration. In other words the $500 Fosgate is not $350 dollars better than the soundstream on a motorcycle.
  #64
Old 06-15-2016, 12:34 PM
yooperhog's Avatar
yooperhog
yooperhog is offline
agree. pn4 1000d and 4 kappas on gf street glide. clear loud music at hiway speed. $540 total including lower pods painted to match. did i mention its loud and clear?
  #65
Old 06-15-2016, 01:48 PM
sponger's Avatar
sponger
sponger is offline
Hey gann, u liking hi level or low level input with a ss amp and krc's?
  #66
Old 06-15-2016, 02:30 PM
Greatsteaks's Avatar
Greatsteaks
Greatsteaks is offline
Well still couldn't leave well enough alone so I installed my BT 6.5's in the lowers and ran them in parallel with the KRC's in the pods. Sounds better at slow speeds and the same at 75. Until I figure out lids and an under the tour pack amp I think this is how it stays till then. Mounted the lower grill cover screens flush, they touch the BT tweeters should that be a problem?
  #67
Old 06-16-2016, 03:04 AM
Gannicus's Avatar
Gannicus
Gannicus is offline
I'm strictly low level input. Always. I don't even entertain the thought of high level inputs. I know there was a discussion a while back HL vs. LL. But for me it's low level all the way!!
  #68
Old 06-16-2016, 08:07 AM
BlackPearl#1's Avatar
BlackPearl#1
BlackPearl#1 is offline
+1 w/Sony anyways!!!
Kris
  #69
Old 06-23-2016, 08:32 PM
Springerfan's Avatar
Springerfan
Springerfan is offline
Reading this thread has me very confused but it doesn't take much. I have an SS pn4.1000D, BT LL with Hertz HCX 165s in the fairing and future plans to add Hertz HCX 690's in the lids when BadDad comes up with an adapter. When I set the gains on the SS I could only get about 1/3 before distortion set in. I wasn't all that disappointed since the SS was cheap and planned on replacing it with an Arc 600.4 soon. The SS doesn't sound bad at all at highway speed but I figured it would be excellent with the 600.4. After reading this thread I am not sure that the 600.4 is going to be worth the extra $.
  #70
Old 06-23-2016, 08:48 PM
yank721's Avatar
yank721
yank721 is offline
Not a guru at all but what is your crossover set at?
Quick Reply: Focal?
