RZ-3000D setting question?
I now have the 2000D amp. I have the 3000D coming. I am upgrading just because. More is more better. The 2000 did not have the cross over setting. The 3000 has a that setting listed as X-over 35HZ to 250HZ. Might have the cart in front of horse but. What is the best way to use that setting? In LPF/FLAT/HPF. Which setting should be used? Whats a good starting point? On the 2000 I am using the F/Full setting. Thanks
Budda109 (05-15-2016)
I played with the amp for what seemed like forever to get it to fit. Finally I got it, took some tweaking. I fired it up and the sound is outstanding. I used the settings from Gannicus. Very nice! The HU goes up to 32 or 35 not sure which one. I was playing a song and had it up to 32. Was crystal clear. May play with the gains at some point but it was very good. Thanks for all the help!
