AMP Power wire 2016 FLTRXS
I am getting ready to install my Biketronics 2 channel amp. I know I need battery power (and the power on trigger but that is all set). When running the power wire from the fairing to the battery are any of you able to get it into the cloth/wire loom or are you putting it in its own loom or are you just tucking it behind the bundle out of sight for the short distance along the frame in front of the gas tank?
What Timbo said. Here's are some pics. Run a negative wire while you are at it so the amp can be grounded directly to the battery. BT doesn't supply long enough ground wire so I used 10g and connected it to there wire under the fairing. The 10g won't plug into the BT amp. If you are trying to keep FM then run the positive wire down one side of the channel and negative down the other side.
Look at your third picture. See the black loom where the wires come out of that plastic channel where I plan on running my wires. I was asking about the part where that black loom is outside of the plastic channel. The black loom is visible from the side. Did you try and get your wires in that? Did you try to hide your wires behind that?
