Hertz ECX or Infinity Kappa's?
#35
#36
interesting! I was out on the bike today and with my Hertz ecx and kw kac1804 amp they get distorted about half volume. I'm gonna try them with the SS Pn4.1000 when I get it hooked up. See what's better the Hertz or Kappa's
#37
The hertz dcx were loud and clear but a little sharp. They sounded great for about 3 hours til they popped.... I guess it's back to the drawing board for me...
#38
The DCX have a peak of 120w, the Kappas 225. There's a significant difference as to which speaker can get louder and take the wattage needed to hear at volumes. Chances are a lower volumes the DCX and ECX have better sound quality, but no way they can get as loud as the kappas. The other key is setting your gains so you don't have distortion otherwise speakers go "pop".
MN, how did you set your gains on the PBR?
#39
#40
1. Try setting your gains with a DMM and the bike running. Often what sounds good parked, you can't hear the distortion once the bike is running and the added volts from being on
2. Turn down your AVC. The spike in voltage to turn the radio up when amplified will cause lead to a distorted signal
