Power Acoustik RZ4-2000D high level wiring
I'm at the point of wiring the amp up and I found a problem. What's printed on the amp and what I found online in a user manual don't match. I'm pretty sure what is printed on the amp is correct since the chassis ground is in between the speaker grounds, but the manual I found online shows different. The manual that came with the amp doesn't show a schematic for high level wiring. I just want to be sure. Did everyone use what it shows on the amp?
Thanks, Justin
Thanks, Justin
I just had the same question with the Soundstream pn4.1000. I was going to use the high level inputs but couldn't figure out why there was a ground wire in the middle. So I went and bought some RCA cables and used those instead. My mex70bt has 5v preamp outs so it will save me some splicing and soldering time.
http://www.poweracoustik.com/pa2012/...Amp-Manual.pdf
Here is the user manual I'm looking at. The plugs don't match up to what it shows on the amp. I just want to make sure I wire it right. I hate to have speakers out of phase. I already soldered the connectors to what the amp shows, but the fairing isn't back on yet. So there is always time to change it.
Autotec (04-10-2016)
