Important information for '14-'16 lower speaker install
Old 05-20-2016, 12:14 PM
jayhawkclint's Avatar
jayhawkclint
jayhawkclint is offline
I used foam baffles and clip nuts. They have worked out okay.
Old 05-20-2016, 12:31 PM
billablehours's Avatar
billablehours
billablehours is offline
The tape goes on the speaker box to fairing interface. I put 1 layer of polyfil in the housing. Those boxes look really small to allow air movement but what do I know.
Old 06-01-2016, 09:22 PM
AteamHD's Avatar
AteamHD
AteamHD is offline
Did you put the tape on the top of the speaker tray?
Old 06-02-2016, 05:31 AM
billablehours
I put the tape on the leading edge of the tray where it contacts the lower when you slip it into place. It prevents the two pieces from vibrating together and holds the tray in place during install. I then put one layer of polyfil in before installing the speakers.
Old 06-02-2016, 08:26 AM
AteamHD's Avatar
AteamHD
AteamHD is offline
Thanks did you keep the hole open in the speaker tray or cover it also with the polyfil?
Also what about the 7.1pros in the fairing did you use any polyfil there?
mjohnson68
04-06-2017 10:43 PM
Tailwind
Audio Systems
03-20-2016 10:08 AM
Harleypingman
Audio Systems
23
04-11-2015 04:58 PM
bayboy75
Audio Systems
01-03-2015 01:53 PM
kyleplusitunes
Touring Parts
08-05-2012 07:21 PM
Quick Reply: Important information for '14-'16 lower speaker install
