Problem with Biketronics amp
Hello,
I recently had installed a Biketronics 4180 amp. I was told that this amp had the new electronics which negated the need for a separate line leveller i.e. It was plug and play.
At low volumes it sounds just fine, but when I crank it up the bass really washes out and sounds distorted. I have the bass setting on the system in the middle i.e. no plus or no minus - just centred.
This is the problem when playing FM radio - I haven't been able to test it using a USB device yet (got to get an IPOD soon!). Maybe the problem is radio reception related?
Any ideas what the issue might be? The speakers fitted are as recommended by Biketronics so they are compatible with the amp. ie BT7Pro in front and Alpine SPR 60 s in rear.
Line leveler was not required I was told
When I was emailing Bill at Biketronics before purchase he told me that the amp I would be getting already had the line levelling circuitry incorporated into it and didn't need an additional / external line leveller. Maybe I mistakenly got one of the older amps without this circuitry?
Hello,
Don't have invoice
There is no line leveling built into the BT amp. Your BT kit should have come with two of these Line Levelers. Check your BT invoice. Was the bike ever flashed by a dealer? And who did the install?
I accidentally deleted the invoice from my email, but as far as I know I never had a line leveller as part of the package (I was told I wouldn't need one)
My dealer did the install. I was told by Biketronics that no flash was needed with this unit.
Granted my kit was for my Roadglide but I think you are just misunderstanding, which is what I did until I got and installed my kit. I asked if I needed a line leveler, and got from the conversation the same as you. However, when my kit arrived, it had a line leveler in the kit. So what he had meant was that I didnt need to order the line leveler seperate, as the kit included one, not that the amp had one built in.
Of course it didnt help much that I dont know very much about the whole stereo thing.
If you ordered them online you should be able to view the invoice after logging in.
Altrnative to line leveler?
It's just that Biketronics has come back to me saying there must be something between the radio speaker outputs and the amp RCA inputs. It should be a line leveller but if one is not present can a connection still be made, say with an adapter cable?
I am going to get the dealership to check to see how it is connected when I get the bike serviced on Monday but I'd like to know if it is possible to make a connection between the radio and amp without a line leveller?
