BT4180 & (4) 602's 14 Ultra..?
Old 03-26-2016, 06:27 AM
Genius's Avatar
Genius
Genius is offline
Default BT4180 & (4) 602's 14 Ultra..?
OK men, I'm about 10 mins away from starting my install..
Big Thanks to LL247 (Jason) for hooking me up with everything I needed,
looks like I got everything I need and all seems good!
For the most part I'm not a total dummy installing amps & speakers..
Questions are..I'm not sure of positive or negative on the speakers or my wires..
The speakers are going in the stock locations with stock wires along with a the BT BO harness.
Also my LL's are they fairly well set or will I need to tweak them, I'm using the stock
6.5 HU.
Thanks,
Old 03-26-2016, 06:58 AM
Bunker's Avatar
Bunker
Bunker is offline
Black stripe wire is negative
LL's stock are good to go, but I'd double check with a multi meter just to be safe.
I and a couple of others, have set the output volts on the LL a little higher. I think I'm currently at .8 volts at 14/17 volume but like I said, stock works fine.
Old 03-26-2016, 07:25 AM
Genius's Avatar
Genius
Genius is offline
Thanks man, any clue as to the speakers +&- there not marked..that I can see?
Old 03-26-2016, 07:33 AM
Covert Olds's Avatar
Covert Olds
Covert Olds is offline
Something l learned a longgggggg time ago...using a 9 volt battery, connect wires to positive and negative. Touch the wires to the speaker terminals. The cone should push out if the polarity is correct. If it pulls in, you have it reversed.
Old 03-26-2016, 10:28 AM
Genius's Avatar
Genius
Genius is offline
Well you'd think I'd have a 9v battery somewhere... Not!
So bump back up for which side is hot on these 602's I'm guessing the smaller side...?
Old 03-26-2016, 10:48 AM
Roadie13's Avatar
Roadie13
Roadie13 is offline
Received 1,193 Likes on 563 Posts
I had the same question and called Arc the other night. The larger of the 2 blades is positive.
Old 03-26-2016, 12:58 PM
Moto Mike's Avatar
Moto Mike
Moto Mike is offline
You can use any battery AA,D ect! Bunker said wire with black stripe is neg. Usually the larger terminal is pos. on a speaker!
Old 03-26-2016, 01:09 PM
Genius's Avatar
Genius
Genius is offline
I think..hope I got it, the small blades on the stock speakers seem to be +
The big ones on the 602's appear to be +
Thanks guys.
Old 03-26-2016, 01:27 PM
Roadie13's Avatar
Roadie13
Roadie13 is offline
Thanks guys.
Yep, HD does crap backwards. I thought I was going nuts - I used to run BT 7.1 in my old bike and they were the same way (+) is small post. Talked to Bill at BT and he explained that since the 7.1 was designed just for Harley they went with the HD convention. Their 6.5s are the opposite (big post is +) because they were designed as a universal fit.
Old 03-26-2016, 02:44 PM
Greatsteaks's Avatar
Greatsteaks
Greatsteaks is offline
Bill at BT told me that as long as you do both speakers on the same channel the same way it won't matter, just don't do them different.
Quick Reply: BT4180 & (4) 602's 14 Ultra..?
