Lower Fairing Speaker Videos
Here's the User EQ I'm using also.
slyedog (03-23-2016)
Bert,
Are you setting your EQ in your garage or out in the open at the volumes you would play your tunes while on the road. I would think something like Sly's curve would be more useful on the road. You have four mid range speakers, yet your EQ is raising the majority of the midrange freqs. I would think at volumes those freqs would clip/max first with those settings keeping you from the most volume you could squeeze out of those speakers.
Bert,
In the meantime I have to troubleshoot an electrical problem that's causing erratic behavior between the hand controls and the 998. I can't make any changes on the 998 without having the ignition on ACC. Then when I do all the light on the 998 will flash. Today while riding when I pulled the brake lever the volume display comes up and the volume goes up and down on it's own. The same will happen with the right turn signal, but only sometimes. To make things worse, when I got home I could not repo any of this in the driveway with the bike running. I did ground the 998 to the triple tree.
Never had anything like this happen with the stock HU installed.
Bert it's good to see your getting the hang of it. Although my curve my not quite meet your taste my goal is that keeping the midrange more flat will allow you to have a little more audible lower and upper end without drowning them out with the midrange boosted so highly. A lot of trial and error. I've had many decks over the years with built in eq's and spent countless days finding sweet spots. Thankfully I had a lot of hell along the way from many audio competition friends that guided me. Keep plugging away and keep that 500-5k or so area as flat as possible. If you find the upper spectrum to shrill or overwhelming then use some attenuation if possible in the crossover networks if you have them. Good Luck, Ride Safe and jam on.
